Doesnt always go into overdrive
Old May 28, 2005 | 09:39 AM
Dwaynez28's Avatar
Hello, I got a 97 Z auto, What do i need to check on my car that would keep the tranny from going into overdrive sometimes? I have the springs from a TransGo shift kit still installed and still have a little snap from 1st to 2nd, cuz i did have a 2800 stall, back to stock now. I have had the PCM reprogrammed and Pcmforless put my shift points up higher. When it does go into overdrive it has been set to kick in around 55mph. Somedays it goes right into overdrive,then some days it stays in fourth. Mostly it wont go right into it, any ideas what might be loose or unpluged? Thanks for any ideas. Dwayne
Old May 30, 2005 | 09:28 PM
Dwaynez28's Avatar
Re: Doesnt always go into overdrive
Any ideas would help, Am i loosing fluid,not enough fluid-got a Hayden tranny cooler--anything at all Thanks Dwayne
Old May 30, 2005 | 11:50 PM
Formula2Camaro's Avatar
Try your transmission linkage. Here is a link to the page on Shoebox's webpage that shows you how to adjust it. http://shbox.com/trans/A4_trans_linkage.html Remember it's a very small amount of adjustment that makes the difference. Hope this helps .
Here is the link to copy and paste incase i coded it wrong earlier...I'm really tired. http://shbox.com/trans/A4_trans_linkage.html
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
BLK1997Z28
May 7, 2015 03:01 PM
jb4xx
Feb 2, 2015 10:00 PM
Z28-CTYHNTR
Jan 20, 2003 03:29 PM
