Differential swap question
I have a Strange 12 bolt rear end with a Yukon differential. I'd like to swap it out with an Eaton Posi unit. Does the pinion gear need to be removed or can the main part of the differential(posi and ring gear) be pulled out after removing the axles but leaving the pinion assy in place?
jjmacdragracing
Dec 10, 2015 05:27 PM
Henson071
Sep 21, 2015 04:31 PM
