Differences in a 1995 4L60e and a 1997 4L60e?
It won't work. The 2 transmissions use a different 3-2 solenoid that ohm different. If you swap them, you'll throw it into fail safe and throw a 3-2 solenoid code.
I've seen "budget" shops attempt to swap the solenoid and harness only. The problem is, the 3-2 down valve, itself, is different. Swapping just the solenoid/harness will create a 3-2 runaway problem on a forced downshift.
BTW, the tail housings and speedometers are different, too.
Frank
CPT
Jan 5, 2015 07:14 PM
