delayed 2-3 shift..how to fix?
Old Jun 21, 2009 | 01:47 PM
lt170chevelle's Avatar
ok i have a 94 4l60e that i just rebuilt red alto clutches and 3-4 .025 clearance and have billet servos and all pinless pistons installed also the 3-4 spring loaded check valve in the drum.when it shifts 2-3 its a good second before the shift completes . how can i get a quicker shift.I am worried i will fry the clutches again if it shifts like that wot.1-2 feels ok and it seems like 3-4 was a little quicker than2-3 but not much.I will be doing a pressure test today to see where its at..by the way i should just check it in reverse right?
Old Jun 21, 2009 | 02:19 PM
blown94's Avatar
maybe you didnt assemble the band servos correctly? is the pin length too short? when you dropped the valve body did you by any chance take the whole separater plate down with it and possibly lose the band anchor lug from the case?
Old Jun 22, 2009 | 07:19 AM
band adjusment is spot on as is the pin legnth. The servos are correctly installed also.and the lug is still in there.
Old Jun 23, 2009 | 06:04 AM
blown94's Avatar
u sure when you dropped the valve body the lug didnt lose the anchor hole on the band. its possible if fell just enough to lose the band anchor?
Old Jun 23, 2009 | 07:31 AM
yeah im pretty sure that the lug is still engaged with the band anchor. Tonight im going to do some pressure tests and see how the presure looks.
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
WobblySausage
Oct 7, 2015 02:44 PM
autoxr166
Sep 25, 2015 04:21 PM
Fatdog2
Sep 16, 2015 11:04 PM
