Could it be the pilot bearing?
Old Feb 9, 2009 | 09:25 AM
JohnD's Avatar
I have the oddest thing happening. When the car is cool, the clutch is as smooth as silk (stock disk, LT4 plate-changed out about 40-50K ago, never raced). When the engine is good and warm, there is a chatter just at the end of engagement. When I replaced the clutch, I used the roller bearing instead of a pilot bushing. Do you suppose that increased clearance when hot in this bearing could be the problem? I've heard of the things coming apart-esp. racing-but this is a new one on me.
Old Feb 9, 2009 | 08:49 PM
Green96Z's Avatar
I think the chatter you are hearing could just be the T/O bearing. Did you check the fitment of the bearing on the input shaft before you installed it to make sure it was a good fit?
On a side note, you should have gone with a bushing.
Old Feb 10, 2009 | 07:59 AM
JohnD's Avatar
I don't think it is the T/O bearing. It is actual engagement chatter right at the last part of engagement-and only when it is hot. I went with the roller bearing because it was a truck part-and yeah, it was probably a mistake.
Old Feb 11, 2009 | 11:58 AM
wrd1972's Avatar
Pilot bearing will not cause the chatter issue. Dont see it being a TOB either. I would guess that through expansion and contraction, the clearances are moving around on the disk causing the problem. Could also be a non-flat flywheel, damaged disk or non-flat PP friction surface. Next ime use the bushing, the roller bearing is trouble.
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
