Converter observations
I think the new forum is a good idea, and I have the first (or actually second) post!
Tonight I finally got to put some miles on my new setup with the TH400 and the 4,200 stall converter. Just FYI, the converter is more than tolerable, I had no problem with the stall at all. I wouldn't like to drive with it all day in traffic, and I'm sure the mileage will suck. But if you were wondering about high stall and drivability, it's not nearly the problem I thought it would be.
Rich Krause
Rich Krause
Re: Converter observations
BTW...we will be needing at LEAST one moderator for this section....
Hmmm...
Interesting Rich
I just bought a 3200 Vigilante and was originally worried about drivability, and thought about going down to 2800 stall speed. But if your not having any problems with 4200, I guess I shouldn't have anything to worry about.
Jason, I'm willing to fill that position
Originally posted by WheelmanZ28
Interesting Rich
Interesting Rich
Rich Krause
So Rich, this is the new converter from Coan they were sending you?
You're not driving through this one? If so, that's great, glad to hear it.
How's it pull on those 3rd gear highway nitrous-hits?
Haven't used the N2O yet, as the tune isn't completely dialled in. It's going on the dyno on Sunday and with any luck I will know the answer then
.Rich Krause
Originally posted by JEDCamino
What final drive gear ratio are you running? I'm considering a change to 3.90s or 4.10s and a 3500 rpm stall converter.
Rich Krause
Hehehehe. Big (small diameter) converters are our friends!
The key with any converter is to put it with the right aplication. No matter what I prefer a Highly efficent converter. My Ynak seems to be right at 4% with 500/500 Power going into it.
I ran a TH400 and 4,200 Stall on the streets for years. Once a year I would freashen the trans and put new bearings and Sprag in the converter.
Short of ripping input shafts out of the forward drum I was good to go
Glad to see we have the new section
Interesting Rich
Interesting Rich
I only got this converter because I was planning ong going with a cam that's bigger than the hot cam. It's been fine for the 191/196 stock B-LT1 cam though
Okay guys need your help. I am fixing to install a 700r behind my motor. done away with the 6 bannger. The car has around 500 horsepower and 175 shot of the go go juice. I am running 4:30 gears in the back. I am going to order a stall in the 3400 to 3600 range. Do you think I would even need a lockup for highway trips with my low gears will I probley be off the converter at say 65mph. Also who do you fell makes the better converter vigilante or yank. Fixing to spend hard earned money your info would be nice.
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Aug 5, 2015 08:35 AM
