Considering going auto and have a few questions
Old Jul 17, 2010 | 11:28 AM
chasmosis1's Avatar
As the title says, I am considering changing to auto as the car is becoming less streetable as a DD. I am currently running a T56 and have a good 4L80E that I will do some mods to. I am running a 9" with 3.50 gears and my motor is in my sig. I am very much mechanically inclined and very good with wiring/electrical.
My questions are these:
(1) Do the auto cars have a separate TCM? My research is saying no. If not than can I load a bin file from an auto into my OBDI converted system and use the same ECM? I have a complete harness and ECM from the truck that donated the 4L80E, so I can graft in the needed wires.
(2) What should be done to the 4L80E to make it stand up?
(3) What stall and rear gearing would be best for my combo?
Thanks, Chas
Old Jul 17, 2010 | 11:38 AM
Kevin Blown 95 TA's Avatar
PCMs are the same between a M6 and an A4 car.
Old Jul 18, 2010 | 08:59 AM
chasmosis1's Avatar
Thank you Kevin Blown 95 TA
Chas
Old Jul 18, 2010 | 09:17 AM
mrbadlt1's Avatar
i would atleast put some red eagle alto clutches in it, alto wide band, large servo, what size cam are you running, that will help you determine stall speed, and final drive gear ratio
Old Aug 19, 2010 | 04:00 PM
Hyphy01SS's Avatar
Thanks, Chas
Are you going to sell the t56?, I have an auto and want to keep a t56 swap on the back burner if i ever get tired of my auto
Moshbmx1
Feb 17, 2015 10:51 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Jan 4, 2015 08:43 AM
