Clutch Problems...
Old Jul 28, 2004 | 11:15 PM
CPFarhood's Avatar
Clutch Problems...
The 98Z in my sig has been updated to a SPEC stage 2 clutch setup with the stock flywheel and i'm having some troubles getting it to disengage. I'm thinking it's the hydraulics but slave or master or both? Is the 01+ master any different (I know the slave is)?
Old Jul 30, 2004 | 08:58 AM
djw's Avatar
djw
Re: Clutch Problems...
I had a similar problem after installing my centerforce clutch. What I found was that the slave cylinder was a little tired, it wasn't moving to its full potential. After replacing the slave cylinder the problem was partially fixed. I can now get it in gear but some of the time it doesn't go in very easily. I am thinking about putting in an adjustable master cylinder and see if that will completely fix the problem.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
