clutch problem?
Old Apr 5, 2004 | 10:32 PM
krillanaross's Avatar
clutch problem?
Hey guys, I was on my way home from school this evening and when I pushed in the clutch and put it in gear, there was a slight vibration and noise coming from the clutch pedal and shifter. When I am cruising on the highway everything seems fine, but when I shift or down shift it does the same thing. (worse when downshifting). Anyone have any idea what it might be? I thought it could be the clutch, but it was replaced not too long ago and shouldn't be going out already. Any help is much appreciated.
Old Apr 5, 2004 | 11:03 PM
SSpdDmon's Avatar
It's possible that your slave cylinder is shot. If the clutch is not fully disengaging the flywheel, you would feel a grind going into a different gear unless the rpms were dead on.
Old Apr 5, 2004 | 11:23 PM
if the slave cylinder is shot, is that a major repair or an easy fix? and is it an expensive repair?
Old Apr 6, 2004 | 08:23 AM
chpmnsws6's Avatar
might be a good time to change out ur clutch for a spec stage 4 and an 01-02 slave cylinder
Old Apr 6, 2004 | 08:52 AM
PhantomTA's Avatar
Moderator
Moving to the drivetrain forum..
sigh
Old Apr 6, 2004 | 11:22 AM
sigh
THANKS DUDE!!!!
Old Apr 6, 2004 | 12:03 PM
6spdpewterZ's Avatar
I concur, I had a the similar problem. When I swapped my clutch, I did not bother to change the actuator and the actuator ended being bad. It was leaking fluid so I had to take the tranny down and swap the darn actuator. It sucks to be lazy... I learned my lesson.
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
