Clutch pedal has 4 inches of play???
Old Apr 5, 2005 | 08:17 AM
Sleeper_Z's Avatar
Hi,
Im having an issue with my clutch pedal. I never really knew anything was up with it till I started working on a friends 94 T/A. I got in his car and noticed that the clutch pedal was around 4 inches higher than mine (almost even with the brake pedal) So I got in my car and looked and sure enough the pedal is around 3 to 4 inches closer to the floor. So I put the toe of my shoe under the pedal and pulled up and there is about 4 inches of free play befor it stops at the top. Whats up with this?? Is my clutch master cylender bad? Or have a bent my clutch pedal stabbing gears?? Im kindof at a loss here, cause everything seems to work ok but the pedal is just really low. Thanks for all your help.
J.
Old Apr 6, 2005 | 03:29 AM
goaliedave40's Avatar
Re: Clutch pedal has 4 inches of play???
Did you check your clutch slave reservoir? Its the small one next to the brake fluid res. Your slave cylinder might be going bad, too. I had to swap mine out last year. Good luck!
Old Apr 6, 2005 | 06:13 AM
SSBOY 2 N V's Avatar
How many miles on the clutch, and is it stock?
Old Apr 6, 2005 | 07:21 PM
Sleeper_Z's Avatar
Yeah I checked to make sure it was full on fluid, and no the clutch is not stock. I have a SPEC stage 4 clutch with about 6,000 miles on it. Im guessing the master cylender might be bad, but Im still open for suggestions. Thanks
J.
Noct
Jul 14, 2015 01:18 AM
whitehooptie
Jul 12, 2015 06:10 PM
surreybrad
Jul 5, 2015 10:36 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
