clutch installation
Old Jan 7, 2007 | 12:47 PM
redsick93lt1's Avatar
clutch installation
i am in process of installing clutch and saw yellow dot on press plate and blue dot on throw out bearing anf nothin on my flwheel to line it up. it went on easily but not sure if its going to vibrate or work improperly. please let me know what the yellow dot lines up with
Old Jan 7, 2007 | 12:58 PM
Firehawk_Dude's Avatar
I'm assuming aftermarket pressure plate and throwout bearing?
Old Jan 7, 2007 | 01:49 PM
yes a ram clutch
Old Jan 7, 2007 | 05:45 PM
OBE1 95Z28's Avatar
There no alignment required of the throw-out bearing; it's a neutrally balanced piece.
Old Jan 7, 2007 | 07:04 PM
what about a certain way the press plate has to go on does the yellow dot on the press plate have to line up with the x on the flywheel
Old Jan 8, 2007 | 09:41 AM
OBE1 95Z28's Avatar
Give Ram a call.
Old Jan 8, 2007 | 12:28 PM
always faster's Avatar
I found this on teh centerforce clutch ,i dont know if its the same with other clutch brand but:
http://www.centerforce.com/mediafiles/I94GM004.pdf
On my stock flywheel there is a small painted "X" on the side of it and on my new pressure plate i got the yellow dot(also got a Ram).
Nov 18, 2023 07:21 PM
BPS
9
Mar 5, 2015 10:51 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
