Clutch install problems
Old Aug 8, 2004 | 03:29 PM
CamaroBoy96Z28's Avatar
Just put in a brand new SPEC stage II and brand new stock flywheel. I got the car going yesterday and it drove ok until I hit 2k and then it fell on its face like the clutch wasnt grabbing hard enough. So just now I took off the slave and bled it. The fork popped off so I went to test out the pedal and heard a crack. The slave pushrod is bent a little now so I need a new one. I saw something in older posts about a slave/master "kit" or something thats already pre-bled from GM. I cant find the part number or the info again for some reason. If anyone can help me out with that, I'd appreciate it. I just want my car back on the road. Thanks in advance.
Old Aug 8, 2004 | 10:20 PM
PatriotTA's Avatar
Re: Clutch install problems
I belive this is the part number you are looking for: 12559912
Old Aug 8, 2004 | 10:29 PM
Dolby109's Avatar
Unless you believe your master cyl is broken I would just buy the slave cyl...
You can put a new slave cyl on and bleed it in half of the time it takes to install that stupid master cylinder.
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
slothgrant
Aug 22, 2002 03:01 PM
