Clutch fork rubbing against pressure plate HELP!!
Old Apr 13, 2011 | 01:03 AM
Henson071's Avatar
OK guys, Im pretty sure the fork is rubbing the pressure plate when the pedal is fully depressed. Brand new engine, flywheel that has been turned a few times, new clutch, new PP, new slave cylinder. I thought maybe the TOB was defective and had the clutch warrantied out, did the same with the slave. Theres markings on the outside of the pressure plate as well as on the clutch fork. Does the fork pivot or the fork wear? Everything is new except the flywheel and the fork/pivot bolt. What could cause this?
Thanks guys for your input,
Danny
97 Camaro Z28 m6
Old Apr 13, 2011 | 08:54 AM
jloshotz's Avatar
Re: Clutch fork rubbing against pressure plate HELP!!
Is it possible that the flywheel is out of spec, cut too many times? Not sure it would cause this, just seems like the only thing that is questionable at this point...hopefully someone else will chime in
BigWil
Mar 29, 2015 12:24 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
