Clutch Failure - Has this happened to anybody?
Old Nov 11, 2014 | 06:38 PM
sooperdood3's Avatar
The spline sleeve on the clutch disc cracked and part of the bracket is missing. Symptoms were rattling noise at takeoff and difficulty getting into gear. Has this happened to anyone before? Is this a common failure?
Car is a 1996 Formula w/ basic bolt-ons. Clutch kit is a Ram 88516 OEM replacement.
Old Nov 30, 2014 | 05:33 PM
AdsoYo's Avatar
Re: Clutch Failure - Has this happened to anybody?
Ouch! I changed out a Competition clutch earlier this year and it had broken/cracked springs but that was it.
Old Dec 1, 2014 | 09:43 AM
When I tore it apart I was expecting a broken or loose spring.
My best guess on how this could have happened is it must have cracked from the shock load when my rear end seized up...it didn't show symptoms for almost 6000 mi though. Plausible?
Old Dec 1, 2014 | 02:20 PM
Chimera96's Avatar
spline failure has happened for various reasons. Typically use & abuse from high RPM clutch dumps. Your rear end locking up while car was in gear and at speed could have also caused it.
some clutch discs are made better than others. Solid machined spline hub being one item that is better on some clutches than others. Might want to consider a kit other than RAM...
replace pilot bearing while you are installing a new clutch kit
BigED
Jun 26, 2015 10:58 PM
blkWidow
Apr 21, 2015 01:56 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Injuneer
Dec 15, 2014 09:36 AM
