Clutch disk installed wrong ?
Old Oct 5, 2009 | 03:13 PM
stephenpen's Avatar
Exclamation Clutch disk installed wrong ?
I just put my engine back together with the help of my buddy and I think he installed my clutch disk backwards. Will the Pressure plate bolt on if the disk is in wrong. I tried to start the car so I pressed the clutch in and it got harder every time I pressed it. Then it lost all pressure and leaked out oil from the slave cylinder. I'm thinking this might be from the cluch disk being installed wrong.
I don't want to get a new slave and brake it because of the disk.
The tranny is bolted to the engine but the shifter, and drive shaft are still out. I don't want to put everything back together if I have to pull the tranny.
If someone knows if the pp will bolt up to a flywheel with the disk on backwards please let me know.
Old Oct 5, 2009 | 03:20 PM
97FormulaWS-6's Avatar
It will go on backwards; but it won't work properly, obviously.
warmeck
Mar 22, 2015 10:28 AM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
slothgrant
Aug 22, 2002 03:01 PM
