Clutch for a 93?
Clutch for a 93?
I've look around these and other forums and haven't come up with much so I'll just ask.
What are good (affordable) clutches for a 93 Z28, mostly stock. No idea on power but with a MASSIVE bog each time on the line it ran a 14.1 3 times in a row so its a high 13 second car if I knew how to drive it better.
Only company I know of is SPEC. But I've heard even the Stage 1s chatter pretty bad. What are my options, and which of them will likely be the best?
I read about a good clutch from SLP but I cannot locate it anywhere.
Ask Delsoto about his setup. I'm put him onto it off of all the suggestions I heard on here. Get the McLeod clutch disk with a good flywheel. Get a AutoZone clutch and take the pressure plate, throwout bearing, and pilot bushing out to use with the other stuff. Delsoto is putting 440rwhp and 390 rwtq to the wheels with this setup. I bet he has nice things to say about it.
