Which clutch for a 600hp LT1?
Old Sep 12, 2005 | 07:55 AM
Procircuit155's Avatar
Car is a 96' SS, driven approx. 100miles a week, will see alot more street time than track. Car is making 450-475rwhp on motor and will be spraying 150-200 wet. I'm thinking a spec stage 4 but was recommended a stage 3. I've also heard that the Mcleod twin is good but how much hp will I loose with the twin disc assy? Suggestions please.
Old Sep 12, 2005 | 08:49 AM
rskrause's Avatar
Moderator
Re: Which clutch for a 600hp LT1?
No question that the Street Twin is BY FAR the best LT1 clutch out there. Only problem with it is cost. Get the aluminum flywheel if you are worried about a couple of hp lost to the rotating mass, but I wouldn't worry about it.
Rich
Old Sep 12, 2005 | 09:37 AM
Alum. flywheel wouldnt' be that great for the street correct?
Old Sep 12, 2005 | 03:03 PM
OBE1 95Z28's Avatar
I have the ST with the aluminum flywheel. The aluminum flywheel helps offset the extra weight of a 2 disk setup plus an intermediate plate. It has great street manners.
Old Sep 12, 2005 | 06:59 PM
Josh'95Z28conv's Avatar
I have a stage 4, although not a lot of power in front of it yet. I love it. Very easy to drive, no chatter at all. Dont even consider the spec stage 3. They have sprung hubs, and spec sprung hubs are weak.
Old Sep 12, 2005 | 09:22 PM
I just want to make sure I get the right clutch the first time, i'd hate to spend 700-1200 and not be happy with the clutch.
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
simple
Aug 11, 2002 11:56 AM
