Checking pinion depth
Old Nov 16, 2007 | 10:27 AM
Style's Avatar
Shop wanted $770 just in labor to install 4.11, so I will be doing it myself again. Last time i did it, i didn't have the means to properly set the pinion depth. What is everyone using?
Old Nov 19, 2007 | 12:34 PM
Compstall's Avatar
There's GOTTA be a cheaper place to do it. I've found many places that typically charge ~$250 for labor only.
Old Nov 19, 2007 | 03:10 PM
Style's Avatar
I agree. The problem is I bought the parts with the intention of doing it myself, but due to time constraints, it would be better to bite the bullet and have someone else do it. Most places will not install part unless you bought it through them, due to profit and warranty of the job performed.
So I ask again, what is everyone using to properly set pinion depth?
Old Nov 19, 2007 | 09:01 PM
jay_lt4's Avatar
it all depends, some gear sets have the pinion depth or mounting depth on them and some brands do not
if they have the pinion depth i then use the simple $100 tool you can buy from summit or jegs, if they have the mounting depth you need to measure the pinion head thickness and subtract that from the mounting depth to get the pinion depth
if they do not have the pinion or mounting depth, then i start with the original pinion shim, set the pinion bearing pre-load, install the carrier and set the carrier bearing pre-load and backlash then take a pattern to see if pinion depth is good
Old Nov 20, 2007 | 12:01 AM
Style's Avatar
thank you my fellow cheesehead!
Old Nov 20, 2007 | 08:53 AM
Mr. Wolf's Avatar
thats what i did on the cutlass/chevelle
Old Nov 20, 2007 | 09:11 AM
danhr's Avatar
pinion depth = gear paint
backlash = dial indicator
Old Nov 20, 2007 | 09:28 AM
matLT1's Avatar
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
