Changing transmission mount
Old Dec 28, 2009 | 06:24 PM
z28rp's Avatar
i never changed the transmission mount on my z, but i can tell its going out. how do i change it, im assuming its just one mount from what i've looked at while under the car. it looks like theres just one cross member that runs left to right under the trans with a single mount between the member and the trans. so do i just unbolt the member, support the trans and just replce the mount? also in th eyearone catalog that the prothane mount is taller than oem, am i better going with a stock mount? thanks in advance.
2001 t-56
Old Dec 28, 2009 | 08:47 PM
johnny6's Avatar
You pretty much got it all down, support tranny, unbolt mount and replace. Believe it or not i've had some great luck with Advance Auto house brand transmission mount Prothane mount will increase chassis vibration, especially at highway speeds but as far as installation goes it's nothing different from the factory one unless there were some recent changes.
Old Dec 29, 2009 | 08:13 AM
z28rp's Avatar
thanks for your input, i think ill go with the oem mount
Old Jan 2, 2010 | 07:46 PM
Bersaglieri's Avatar
I recommend a Polyurethane mount since I've seen just about every stock one on a Fbody broken at one point or another.
-Dustin-
Old Jan 13, 2010 | 02:15 PM
z28rp's Avatar
but will i get bad vibration at highway speeds?
Old Jan 13, 2010 | 03:16 PM
Not unless you have other problems. AKA Driveshaft out of balance, or anything else out of balance in the driveline.
Will you feel more vibration, yes. But I dont think it's going to be bad.
-Dustin-
Old Jan 14, 2010 | 02:37 PM
bluz28's Avatar
Just get the ES poly trans mount, then grind down the two pre-load bumps flat. I installed mine that way with the pre-load plate, I have little to no added noise/vibration. BTH, this is my second ES trans mount I have done this way, the first lasted 8yrs.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
