Changed clutch, wont go into gear... help!
Old Oct 29, 2007 | 08:54 AM
Mike96z's Avatar
Alright, changed the clutch on a 1992 RS Camaro 5.0, it has the 5spd transmission and the clutch isnt in backwards or anything and the problem is the car will start, but when I go to put it in gear, i have the clutch pedal down and still wont go into gear. I have some pressure in the pedal but I looked at the slave while it was being pushed and only pushes the fork about 1-1/2", should it be pushing it out more? I am 100% sure the clutch is in correct, done this 1000x and never had one that wouldnt work, I personally think its a bad slave. and the clutch disk in backwards wouldmake it hard for the pressure plate to bolt down. Any input is greatly appreciated. Thanks
Old Oct 29, 2007 | 09:11 PM
Green96Z's Avatar
Uh, Im not too familiar with the 3rd Gens, but do they have a hydraulic clutch linkage? If so, bleed it.
Old Oct 30, 2007 | 12:03 PM
94Camaro_Z_28's Avatar
I would try to bleed it....if that doesn't solve it it definitly sounds like a hydraulics issue IMO.
Old Oct 30, 2007 | 01:11 PM
Mike96z's Avatar
no its the clutch fork, the support that is on the 3rd gen forks is a thin sheet metal finger on both sides, mine broke on one side.
MyfateZ28
Jun 19, 2015 03:42 AM
anmar A
May 2, 2015 06:59 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
