Can't shift into reverse
Yes, There is a reverse lockout solenoid on your transmission. It's located on the drivers side of the transmission near the shifter housing on the rear housing. Try unplugging it first...if that fixes the problem you can choose to replace it or not. If it doesn't work, remove it and see if things move freely...
That was it!!! Thanks Injuneer
Funny story about the fuse box under the hood. The cap that has the layout of the fuses was apparently from another year of f-body. I looked it up in my Chiltons and most of them were different from the cap.
You saved me a lot of time and money!
Thanks,
Kevin
Thanks,
Kevin
Changed the fuse. Drove the car once and the fuse blew. What else could casue the fuse to blow? Injuneer where can i find what else works off that fuse? I hope it isn't going to be to hard to track down.
Thanks,
Thanks,
As I already said, your Owner's Manual (page 231) tells you exactly what is on each fuse. If you don't have an Owner's Manual, get the online copy via Shoebox's website:
http://shbox.com/pdf/manuals.html
WobblySausage
Oct 7, 2015 10:09 AM
