Can't get them off.
Old Nov 28, 2003 | 11:30 PM
Heatmaker's Avatar
Advanced Member
Can't get them off.
If there any way to get the Carrier Bearings off? or the Pinion Bearings off? without goign to the shop? how so? what would I need?
Old Nov 29, 2003 | 12:23 AM
2000zee28's Avatar
I have done a few 10 bolts in the last year. I took my dremel carefully cut the pressed on portion of the bearing so it was almost cut through. Then using a cold chisel I split the bearing, tapped in off. Then I installed the new bearings using the old split bearing with a hammer to tap the new bearings on. Worked fine.
Just take yourtime, wear safety glasses and don't cut too deep.
Old Nov 29, 2003 | 01:27 AM
Heatmaker's Avatar
Advanced Member
That's funny you say that because thats what I just attempted..but the shape of the Eaton makes it hard to Cut. I don't wanna mess my diff up so I guess I'll take it up the *** for 20 at the shoppe. thoght maybe there was some tool or something?
Old Nov 29, 2003 | 10:41 AM
HBHRacing's Avatar
a shop can use a press to get the pinion bearing off/an as well as a puller that is used to get the diff berings off
Old Nov 30, 2003 | 06:14 PM
scooters97ss's Avatar
Mechanics have to eat too man. There are tools to take them off with, and they cost big bucks too; you wouldn't get that done for $20 where I work. I don't know why people think all mechanics should work for free. Do you work for nothing? I'm not trying to get into a pissing match either; that just gets to me. Have a good one.
PopoFormula
Oct 12, 2015 04:19 PM
alliance12364
Sep 23, 2015 12:40 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
4586
Aug 24, 2015 11:04 PM
