can tranny take 360rwhp?
Old Mar 13, 2007 | 11:38 PM
camz28aro's Avatar
i have an 02 z28 and wana beat this kids 04 cobra.
if i keep the stock converter, street tires and go to 3.23 gears would the 4L60E need a kit from pro-built or CPT or can i stay stock. im not going to go any higher than 360rwhp. thanks.
Old Mar 14, 2007 | 06:41 AM
12SCNDZ's Avatar
With 360 RWHP, you'll probably be in need of a good rebuild. Something built to take the extra abuse.
Frank
CPT
Old Mar 14, 2007 | 01:34 PM
Jazsun's Avatar
Definitly the A4's in the 4th gens are only rated at like 300 lbs torque.
Old Mar 14, 2007 | 03:27 PM
2000GTP's Avatar
When my friend did a mild heads/cam package on his LS1, it didn't take much time for him to start trashing factory trannies and rears.
Old Mar 18, 2007 | 08:48 PM
camz28aro's Avatar
thanks, does anybody have around 350-360rwhp/tq right now on their stock 4L60e without any problems yet?
Old Mar 18, 2007 | 09:27 PM
myslowcamaro's Avatar
im jinxing myself by posting this, so i better bring a trailer now to maple grove raceway for the pinks meet.
i have dyno'ed 420rwhp on a stock tc and aftermarket 3.73's in a stock 10 bolt. my tranny is fine. i promise frank the work when i do blow it up but for now i dont need it yet. might be a differant story when i put a higher stall tc in. and yes, thats on bfg dr's.
Old Mar 19, 2007 | 01:46 AM
Pro Built Automatics's Avatar
A good torque converter, such as a Vigilante will give you the most in a performance increase, and is much easier on the geartrain, due to its lighter weight, and is only going to help all around. Depending on how you drive will determine what stall to go with. Second would be a rear end gear ratio change. You mention going to 3.23's, what rear end gear ratio do you have now? This transmission has low miles and if you are not experiencing any shifting problems, and the fluid is in good shape, it should hold for awhile.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
