can tranny take 360rwhp?
i have an 02 z28 and wana beat this kids 04 cobra.
if i keep the stock converter, street tires and go to 3.23 gears would the 4L60E need a kit from pro-built or CPT or can i stay stock. im not going to go any higher than 360rwhp. thanks.
im jinxing myself by posting this, so i better bring a trailer now to maple grove raceway for the pinks meet.
i have dyno'ed 420rwhp on a stock tc and aftermarket 3.73's in a stock 10 bolt. my tranny is fine. i promise frank the work when i do blow it up but for now i dont need it yet. might be a differant story when i put a higher stall tc in. and yes, thats on bfg dr's.
A good torque converter, such as a Vigilante will give you the most in a performance increase, and is much easier on the geartrain, due to its lighter weight, and is only going to help all around. Depending on how you drive will determine what stall to go with. Second would be a rear end gear ratio change. You mention going to 3.23's, what rear end gear ratio do you have now? This transmission has low miles and if you are not experiencing any shifting problems, and the fluid is in good shape, it should hold for awhile.
