Bye Bye Traction! Stall Installed...
Old Jul 8, 2006 | 03:10 PM
TobyZ28's Avatar
So I threw in a 2800 Yank Converter and I absolutly LOVE it. Now.. I can barely get any traction.
Anyone have any advice for launching now w/ a higher stall converter? Do you guys find launches better doing a brake stall to launch or just going 50% or so off the line and easing it up to WOT?
First hard launch I tried i was spinning tires for a good 3 seconds in one place
Slicks and other suspension mods are not in the budget right now
Old Jul 8, 2006 | 03:40 PM
2000GTP's Avatar
Re: Bye Bye Traction! Stall Installed...
Very nice. My car is due up for a tranny refreshening pretty soon in which it will also get a higher stall Vig. converter. Can't wait.
Old Jul 8, 2006 | 03:42 PM
Bersaglieri's Avatar
I am pretty sure those 2800 Yanks for our cars are just restalled stockers. Go to a Vigilante and that will blow your tires off. I have 17x11's in the rear and traction isnt found till 3/4 thru second.
-Dustin-
Old Jul 8, 2006 | 08:21 PM
TobyZ28's Avatar
I bet your Richmond 3.73's have something to do w/ that too Anyhow.. anyone have some launch tips? What seems to work best... is it just a matter of going ez on the throttle?
Old Jul 8, 2006 | 08:28 PM
Honda Hunter's Avatar
-Dustin-
I'm pretty sure most stalls that low are just restalled stockers mabey. Doesnt mean he needs to go with a Vig.
Old Jul 13, 2006 | 07:45 AM
Not really most stalls just certain ones. 2800 Edge, Vigilante, Midwest and Fuddle's arent stock restalls. But Yank and SLP are.
I'm not really saying he needs a Vigilante, but I am saying that it will really blow the tires off compared to a restalled stocker. The STR's are much different.
The 3.73's probably dont help, but, with the stock stall I didnt have 1/2 as much problem with traction as I do now. Its all about STR and how hard it hits the tires. Vigilantes are known to hit pretty hard, and let me tell you, they arent kidding.
I recommend going easy into the throttle to not flash the converter until your tires are rolling, experiment to find out what speed works best. But really a stall is only going to benefit with traction, so my second recommendation is sticky and or bigger meats.
-Dustin-
Old Jul 13, 2006 | 08:18 AM
I'm pretty sure the fuddle is a restall. It's all about the STR, that's correct so stall for stall if it's rated the same it's about which is more efficiant. I hear vigs arent but I dont know for sure.
Old Jul 13, 2006 | 09:36 AM
I'm having trouble following your wording, but my point is that the restalled stockers have low STR's. Usually in the 1.9-2.1 range. Vigilantes are a strong 2.5. Hence my comment about the Vigilante blowing the tires off more-so than a restalled stocker.
I never heard that Vig's are inefficient at all, quite the opposite actually.
-Dustin-
Old Jul 13, 2006 | 10:11 AM
Capn Pete's Avatar
I think tires are probably the only REAL solution to poor traction?
How about LCA's and/or relocation brackets ... have you done those?
Old Jul 13, 2006 | 12:03 PM
Cmr0z28's Avatar
suspension and tires.
launch technique? smash the gas pedal to the floor and hold it that way until you pass the finish line.
Old Jul 13, 2006 | 12:16 PM
frankthetank078's Avatar
factory stall is extremely low around 1200.. but some good suspension like LCA and a subframe connector should help... i have the exact same problem
Old Jul 13, 2006 | 07:16 PM
1997Z's Avatar
I have 245/16 Nitto 555R's and they do not hook either. Hot days and concrete work the best... I launch at 1/2 - 3/4 throttle and mash it after I get going. My rear goes sideways on the 1-2 shift and barks on the 2-3 shift. I raced a newer 4.6 with headers and Magnaflow (and more I am sure) and I quickly pulled a car on him with my Nittos squealing. I shutdown after that. Can't afford to get in trouble on my lunch hour! Plus I am a big guy and I had a passenger! Unreal.
I love the way my car drives now. Though the MPG SUCKS bad!
Old Jul 14, 2006 | 04:40 AM
TobyZ28's Avatar
That tecnique (after the stall) results in standing Burnout until i let off the gass now
I think the first step for me will be taking everyones advice and getting LCA relocation brackets welded in and see how that helps. Tires are kinda outta the question as this is my daily driver and it rains a lot in vancouver.
Tnx for the suggestions Im finding the best launch technique is to 50% it and then mash it once i'm going a bit off the line. I gotta say though the best part of a new converter is stomping on the gas from a slow roll! The car just takes off like never before, and squeels into 2nd. I'm sure it'll be equally fun once i can hookup too!
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
