Busted driveshaft?
Old May 29, 2007 | 03:21 AM
  #16
Pyrodawg's Avatar
Originally Posted by Craddock
I think the early 94's and 93's had the two piece driveshafts. The driveshaft is still in place as it's connected to everything from what I can see. Could it break in the center but you couldn't see it cause the bushing? If it is the pinion gear how much work am I looking at?
sorry friend but no 4th gen fbody came with a 2 piece driveshaft
Old May 29, 2007 | 03:27 AM
  #17
95ttoplt1's Avatar
I have had a couple of drive shaft failures in other cars and never once did the drive shaft stay attached to the car, one we never found.
I think R&P or something in the tranny.
Old May 29, 2007 | 03:36 AM
  #18
Nitelite's Avatar
Actually I did a fast search and found a few people claiming their 93s had 2 piece shafts. (Edit: This guys is a 97 though, so maybe its on the v6 camaros?)
http://www.killebrewonline.com/Car/97suspension.htm is where I found it, and http://www.killebrewonline.com/Car/9...riveshafts.jpg is the picture of the new v8 driveshaft and his old 2piece stock.
Old May 29, 2007 | 04:51 AM
  #19
Craddock's Avatar
I've already claimed ignorance on the drivetrain past the transmission, but it looks like two pieces. Could the universal joint fail? How much should I be able to move the driveshaft side to side by hand?
Old May 29, 2007 | 05:00 AM
  #20
Pyrodawg's Avatar
if its on anything its on V6s, no 93 Z28/TA/Firehawk/Formula came with a 2piece
Old May 29, 2007 | 05:01 AM
  #21
Nitelite's Avatar
Side to side? I would think very little to none. I don't know much about 2 piece driveshafts, and if it busted at the knuckle I guess it would move side to side more? Best thing to do is jack it up and check it out!
Old May 29, 2007 | 05:07 AM
  #22
Craddock's Avatar
Already jacked it up last night to check it out, but that was at midnight, and I'm having it towed home this morning, I'll try to get pics of it. Some dumbass might have put a V6 driveshaft on it cause it doesn't have the original transmission. But you can definitely move it much more than I expected, maybe two inches from side to side. I'll get it in this morning and up on jackstands in the light.
Old May 29, 2007 | 05:31 AM
  #23
PLEASE post on the correct forum..... this doesn't belong on LT1/LT4 Engine Tech.
Moving......
The V6's had 2-piece driveshafts, up to some time in the late 90's. The V8's never had 2-piece driveshafts.
Old May 29, 2007 | 05:33 AM
  #24
Craddock's Avatar
This originated with what all years could I get to replace the lt1 driveshaft, that's why I put it in here.
Old May 29, 2007 | 01:07 PM
  #25
LT1 ENGINE Tech is only for questions about (surprise) LT1 ENGINES. Not LT1 driveshafts. Not sure how this could be made any clearer.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
realistyc
Jul 28, 2015 07:32 PM
