bleeding the clutch
Old May 19, 2006 | 12:43 AM
cralarcon_IROCZ's Avatar
bleeding the clutch
Does anyone know where the bleeder screw is for the t56
Old May 19, 2006 | 07:39 AM
teke184's Avatar
Re: bleeding the clutch
driver side of the transmission...just above the hydrolic hose that goes in it.
find the seam where the trans bolts to the bellhousing...and run your fingers up...you'll hit the hose first...then above that (way up in the tunnel) you'll find the hole for the bleeder screw.
its a PITA to get to.
use a mity vac it's much faster
Old May 22, 2006 | 12:07 PM
If i were to bleed the system not using a vacuum....how many times does it typically take to get all the air out the system? Also...when i was bleeding the clutch the pedal stayed down to the floor after opening the bleeder valve...should that happen?
Old May 22, 2006 | 03:08 PM
teke184's Avatar
i've heard 50+ times...
and i don't think it's a big deal if the pedal stays down. there isn't any pressure forcing it back up.
Old May 25, 2006 | 05:34 PM
One more question. What size tube will fit on the bleeder valve? is it the same for the bleeder screw on the brake calibers? Using a vacuum...how much pressure should be used?
Old May 26, 2006 | 07:27 AM
teke184's Avatar
bout half way down it describes how to use a vacumn
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
1bad427ls1
Sep 23, 2015 01:12 AM
