Big converter in a 94Z ?
Old Apr 3, 2004 | 01:01 PM
BMCioli's Avatar
I heard you can put a big converter in a OBD1 for some reasone ? From what i hear it wont shift under WOT. Can i tune it to shift ok with LT1 edit ? or am i gonna have to put a th400 or go to OBD2 ? and help would be helpful thanx
Old Apr 3, 2004 | 03:09 PM
RyanS_Z28's Avatar
maybe you should rephrase? you WANT to put a big torque converter on your 94?
Old Apr 3, 2004 | 04:34 PM
flyinZ's Avatar
Yep, u heard right..Some guys are having problems with there cars not shifting from 1-2, or somtimes 2-3....U can tune around this problem.
Old Apr 3, 2004 | 04:42 PM
chesee48's Avatar
Re: Big converter in a 94Z ?
what!?
Old Apr 3, 2004 | 04:46 PM
madwolf's Avatar
He meant installing a high stall converter....
Yes, some people experience problems with torque converters 2800 or higher on 94-95 cars. The problem is manifested through a NO SHIFT from first to 2nd gear at wide open throttle, setting an SES light and soft landing in 3rd gear.
There is a programming fix for it but it doesn't work on all cars. Converting to OBDII is an option that will work in case you DO get this problem, but I wouldn't go as far as converting to a Th-400 for this reason, unless you specifically want the Th-400.
Old Apr 8, 2004 | 01:00 PM
BMCioli's Avatar
thanx for the help guys, yes when i said big i ment a big stall like 3800-4400 this is gonna be mainly a track only car. So i can have it tuned so that it will shift with a higher stall ? thanx for the info
gomaro
Events and Cruise Spots
May 6, 2015 09:02 AM
timmy39120
May 2, 2015 05:12 PM
kksi
Mar 21, 2015 09:03 PM
mschmidt33
Mar 15, 2015 07:20 PM
