Best Drag Racing Posi???
Old Apr 24, 2005 | 03:51 PM
  #16
markinkc69z's Avatar
Re: Best Drag Racing Posi???
Don't use any limited slip lube in your eaton and it will stick a little better, but will chatter around tight turns and require service sooner. If you don't have 15" wide tires I would stick with the 400# springs. The harder you shock a clutch type differential on the launch the better they work. The new eatons use a carbon clutch pack, vs. the metallic one I have in my '69. I do have Scheiffer springs which I believe are 600#, they're yellow in color, and yes they are old. I've only obliterated my 12bolt once, and I've been damn hard on it. Its gone 9.80s on 9" tires with n2o on the launch.
9t4lt4z28
Jun 21, 2015 08:18 PM
Flint78
Jun 21, 2015 01:28 PM
Camarokid95
Jun 12, 2015 11:25 PM
Elcojoe
Nov 17, 2014 10:27 PM
Notford95
Aug 20, 2002 01:46 AM
