Bearings?
Old Jul 16, 2004 | 06:35 AM
JB_96RS's Avatar
Wink Bearings?
What/how many bearings are there inside of my rear end (hold the laughter)? The humming is making me what to jam a sharp object in my ears! There is also a vibration that can be felt in the center channel that seems to be related to the humming. Any ideas on this?
Old Jul 16, 2004 | 06:02 PM
JB_96RS's Avatar
Anyone? Where are the weights on the driveshaft to balance it?
Old Jul 16, 2004 | 06:05 PM
n2ceptor's Avatar
Pinion bearings, carrier bearings, and axle bearings..... The humming could be from the ring/ pinion wear....
Old Jul 18, 2004 | 06:23 AM
97ss497's Avatar
My pinion bearing was bad; it caused a constant "humming" noise. I had all six bearings replaced and also changed the ring and pinion to a 4:10. I just put it back in the car and have about 30 more miles to go for the break in period. She's real quiet now; I'm totaly impressed with the GM gears.
Your looking at around $150 labor to have the bearings replaced; a complete bearing kit will run you around $125 from Summit.
Good Luck
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
