balancing a internally ballanced street twin for use on a stock shortblock
I bought a street twin from Jason Short a few months ago. I am just getting around to the point of needing to install it (my current disk is dying a slow death). Jason had the clutch balanced for use with his 396 rotating assembly. I plan on using it behind my stock 94 shortblock. I believe that he said that it was internally balanced. I noticed that there are no bolt on weights on the steel flywheel. I read in another thread that to use a street twin on a stock short block there should be a bolt on weight on the flywheel.
I called a local speed shop and inquired about having the street twin balanced to the stock clutch specs. The owner told me that if I brought the stock flywheel in they could get close. "close" scares me. I called Mcloud and have not been able to get throuth to the tech line.
Can I just order a bolt on weight from Mcloud our will I need to have the whole clutch rebalanced? If so would it be best to ship it to Mcloud and have them do it?
Thanks for the info.
Kory
Kory
