Auto to 6-Speed swap ???
Old Apr 7, 2004 | 08:05 PM
2fbodies2NV's Avatar
Question Auto to 6-Speed swap ???
I'm thinkin' about swapping out my auto for a 6-speed. What Parts do I need ? Is the cross member different ? What about the computer ? How long does this swap take? Can I do it in a day w/ air tools & a lift ? I can have the auto out in about an hour.
Old Apr 8, 2004 | 06:33 AM
v7guy's Avatar
if you do a search you will find some very detailed posts about this as it is brought up quite often
just a quick rundown, you need the pedals, a bell housing, the tranny, the crossmember, the slave cylinder, and a clutch of course, you don't always get a shifter so you may need that, you'll need to cut a hole in the firewall and in the tunnel for the shifter, the computer tables for the tranny can be rpogrammed out or you can get a computer from a M6 car, whichever works best for you, you'll also have to splice two wires to get the reverse lights to work, there may be more, it's been a couple years since I did it and I'm very tired right now, so I may have left out a thing or two, yes you can do this in a day, but it'll be a long day
Old Apr 8, 2004 | 11:27 AM
Mystic95Z's Avatar
I just started my swap today and I'm going by Alex's guide which can be found here. It lists all the parts you'll need as well.
-Tony
Old Apr 8, 2004 | 06:11 PM
Thanx alot. I'ts hard for me to do a search because it takes FOREVER as I'm using my cell phone to connect. Appreciate the help !
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
rideordie
Nov 5, 2019 04:52 PM
Moshbmx1
Feb 17, 2015 10:51 AM
Nostang 96z
Sep 14, 2002 08:22 PM
