Auburn posi and chattering?
Old Jul 12, 2007 | 09:15 PM
Z-RATED94's Avatar
The shop that installed the Auburn Pro Series posi put Royal Purple syn. in the rearened. Now a 1k miles later it is starting to chatter on tight turns. I only drove like this for two days. My guestion is, do you think I did any damage to the unit. I went out and picked up some conventional gear lube and a bottle of additive. Do you think it will be all right if I change the fluid?
Old Jul 12, 2007 | 10:40 PM
n2ceptor's Avatar
Auborn recommends 80w90 dino gear oil .....NO synth....
I made that mistake after 300 miles..Changed to Dino and no problems in 4years....
When you pull of the diff cover check for metal....
Old Jul 12, 2007 | 10:49 PM
mdacton's Avatar
not sure if they rec it or not....but did you put in any friction modifier?
Old Jul 13, 2007 | 07:22 AM
Z-RATED94's Avatar
After asking the shop why they used the Royal purple they said something along the lines of, we use it on all posi units except such and such. I then told them I was on the Auburn web site and found out that they recommend dyno gear lube. Was news to them.
Like I said it only chattered a little before I stopped driving it. So I'll put the Lucas in with the additive. Thanks for telling me yours was all right after you switched. Rick
vwb11356
Jul 22, 2015 06:51 PM
Jul 17, 2015 02:47 PM
Boss002
Jul 9, 2015 03:33 PM
mrwz28
Jul 8, 2015 09:11 PM
