Anyone using a drainplug on their 4L60?
Old Feb 9, 2006 | 10:57 AM
JasonK94Z's Avatar
I wish I would have put a drain plug in my pan when i had Frank rebuild my trans. Sure seems like it would make fluid changes a lot easier.
BUT, do the drainplug kits leak?
Old Feb 9, 2006 | 12:00 PM
12SCNDZ's Avatar
Re: Anyone using a drainplug on their 4L60?
Sure would've been easier when we built it...LOL I'm not a big fan of the drain plug kits, because they use a nut to secure them inside the pan. Because of this, you never get all the fluid out, unless you drop the pan also. The nut leaves about 3/8" of old fluid in the pan. The best way is to drill the pan, and have the nut welded to the outside if the pan. Best location is in the front/bottom of the pan.
Frank
CPT
Old Feb 9, 2006 | 04:04 PM
JasonK94Z's Avatar
Thanks Frank. I just wanted a plug to drain the pan before I drop it to change the filter (when it comes time for service of course). Just keeps my clumsy self from spilling several quarts all over the garage floor
Old Feb 9, 2006 | 04:14 PM
camaros4ever's Avatar
Hey I used to use one on my '98 Z71, same tranny, it made things a lot easier when changing the fuild, I never had a problem with mine leaking.
Cam's maro
Aug 11, 2015 07:45 AM
alphaauto
Jul 26, 2015 04:40 PM
Steve40th396
Jul 1, 2015 09:36 PM
Gio93z
May 21, 2015 02:56 PM
sc93
May 8, 2003 03:28 PM
