Anyone with u-joint knowledge please read
Old Dec 29, 2006 | 02:23 PM
mdacton's Avatar
I was running my T-56 and steel driveshaft... swapped to a th350 and when I go to the driveshaft shop today they tell me that moser doesen't put 1310 yokes on 35 spline pinions it has to be a 1-ton 1350, they told me what to do.I come home and check it...sure enough I was running the wrong u-joint
I don't see any damage or wear at all.
My question is...they do not make a 1350 trans yoke for the 350(so I was told) He said my option was either a cast HD spicer for a 700r for a 1-ton truck that can be modified to fit....cut a the end off and bevel or buy the strange for the 700r
Should I go this route to run a 1350 up front or would a 1310 be fine in the front? He says I don't need the 1350 without a T-brake
Should I go with the 1350 in the rear and 1310 in the front?
Car should make 400-450 at the wheels
Old Jan 2, 2007 | 07:27 PM
mdacton's Avatar
got the driveshaft today....called in and gave the measuments it was done by lunch time
very satisfied, was only $220, 3" dom 083 I did supply my own trans yoke with 1350 joints
kksi
May 1, 2015 11:36 PM
jerv1c
Mar 31, 2015 01:37 AM
carl.froehlich
Mar 13, 2015 12:38 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
