Anyone make a transbrake for 4l60e?
I buy them new and install them in my transmissions. I'm not sure if the used only info is correct. I have now installed 4 of them new and so far so good. IDK I guess we will have to see what happens. One of which is a 4200lb truck that is shooting for some kind of record with a 4l60e. I did use a billet input and a billet output shaft to help eliminate any breakage. We did advise against this build but I guess the wallet was bigger than mind. The unit was over 5K with a converter. SICK
It gets very expensive and when its all said and done what do you have a 4l60 with a brake in it.......that probly won't last very long. Its one of those polishing a turd situations
Th400 w/ brake - otherwise you're limited to 1 company setting the price on a part because nobody else is willing to develop one.
I'm so glad I got out of the F-body/LT1 realms - lack of support from vendors, overpricing of parts, lack of vendors period and ultimately if you want to go fast - you're limited on the weak tranny and rearend.
Want a brake? TH400
Want to launch hard? 9 inch or 12 bolt $$$$$
Almost can't win.
Want a brake? TH400
Almost can't win.
Brake_L8
Jan 20, 2015 09:44 AM
