Any issues using a 4 channel rear end in '93 if not using ABS?
Old Oct 28, 2007 | 12:36 PM
97bowtie's Avatar
Any issues using a 4 channel rear end in the '93 if I'm not utilizing the ABS? The rear is from a '00 Z28.
Old Oct 28, 2007 | 02:41 PM
94Camaro_Z_28's Avatar
If you're not using ABS they're mechanically the same. It'll bolt in without a problem.
Old Oct 28, 2007 | 05:50 PM
OBE1 95Z28's Avatar
I agree with the post above. The difference is the reluctors (2) for the ABS system is located out next to the disc brakes on the 4 channel system, instead of one reluctor in the gear housing.
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
