Annoying Gear Shifter Problem
Old Oct 15, 2009 | 08:10 AM
rangers458's Avatar
Every morning, first time I go to put the car in gear, the button on the shifter is hard to engage. If I squeeze it real hard, it finally goes in, and I can hear the safety relay finally click below the dash.. YES I DO HAVE MY FOOT ON THE BRAKE!
After this first wrestling match, it works fine for the rest of the day until the next morning...
I don't think it is the brake safety switch, but possibly a contact in the gear shifter. What is the easiest way to take the gear shifter apart?
Thanks.
Old Oct 15, 2009 | 09:55 AM
Unplug the BTSI solenoid (it's under the shift indicator plate) and see if it works freely. That will help you isolate the problem. I think the solenoid has a tendency to be sluggish when cold.
http://shbox.com/trans/park_lock1.jpg
Safety Note: with the solenoid unplugged, you will be able to move the gear selector anywhere at any time when the key is not in the LOCK position.
Old Oct 15, 2009 | 04:16 PM
rangers458's Avatar
Shoebox,
You have this 95 down in your head like I have my old 67 even though it has been in storage for 10 years... LOL!
Thanks, I will check that out....
Old Oct 16, 2009 | 05:57 PM
rangers458's Avatar
Shoebox,
Should I just disconnect the electrical connector, and what the hell is the trick to do that, or do I remove the shaft?
Old Oct 16, 2009 | 06:39 PM
Originally Posted by rangers458
Shoebox,
Unplug the electrical connector. There is a little pin you have to pull to be able to unplug.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
tds1213
Nov 27, 2014 12:55 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
