Aluminum Driveshaft
Old Oct 25, 2007 | 05:10 PM
SSmoknLT1's Avatar
Aluminum Driveshaft
Do All Ls1 F-bodys Have An Aluminum Driveshaft?
Old Oct 25, 2007 | 05:12 PM
danhr's Avatar
no
lt1's came with steel driveshafts
and automatic ls1's with the 2.7X (i forget what it is at the moment) got a steel driveshaft as well
Old Oct 25, 2007 | 05:28 PM
2001NBMZ28's Avatar
My 2.73 A4 car came with steel. The M6 3.42 and A4 3.23 cars supposedly came w/alum, but have seen posts where that wasn't always the case.
Old Oct 25, 2007 | 05:39 PM
Daniel6718's Avatar
ive always seen aluminum besides 2.73 cars
Old Oct 25, 2007 | 09:08 PM
Style's Avatar
There was a TSB to cover vibration at higher speeds. The replacement for these steel shafts of joy were the aluminum shaft. In the LS1's, this new shaft was standard.
Old Oct 25, 2007 | 11:01 PM
SSmoknLT1's Avatar
would that TSB be coverd by the powertrain warranty?
Old Oct 26, 2007 | 09:29 AM
Wild Willy's Avatar
Uh, not in my 2001 LS1 Z28- I got the (lack of) performance 2.73 rear end and a steel driveshaft- fixed that, though.....
Old Nov 20, 2007 | 03:59 PM
golddot's Avatar
can anyone provide the TSB or part number for the alum DS?
Old Nov 23, 2007 | 06:19 PM
MaxPower Z28's Avatar
http://ws6.bambeezer.com/tsb.gif
That's the TSB to cover the vibeshaft.
Old Nov 23, 2007 | 08:06 PM
walt355's Avatar
If your planning on Doing some stuff to your car Id look at another option than another Stock aluminum Driveshaft. Ive seen quite a few brak when they get around the 400 HP range and they start cutting 1.6 60s on a stock weight car.
Old Nov 25, 2007 | 08:04 AM
The Engineer's Avatar
I had a custom aluminum drive-shaft built locally with 1350 U-Joints front and rear. It has held-up without any problems (10.80s w/ 10.5 slicks and 1.48 60 fts).
WD
The bottom drive-shaft is a stock LS.
Old Nov 25, 2007 | 09:10 AM
rskrause's Avatar
Moderator
I would use a CM shift for a car that is run on a drag strip with sticky tires. If it is purely a street car, than a quality aluminum shaft as pictured would be a good choice.
Rich
Old Nov 25, 2007 | 10:27 AM
Rich
My custom-built aluminum is holding up at the strip just fine. About 250 10.80-90 runs last season w/ sticky tires (Goodyear 28" x 10.5).
WD
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
