About to replace my clutch...
Old Nov 16, 2003 | 09:05 PM
95Blackhawk's Avatar
And have a question on how the fork is removed. I have seen install websites where they say pull it off the TO bearing and some say you have to uncscrew it before fully taking out the tranny.
I do not understand since I see no reason why I cannot just fully pull out my tranny first and then get to my fork.
Any clarifications?
Thanks,
Ben
Old Nov 16, 2003 | 09:48 PM
mavricki18's Avatar
I dont think a T-56 has a fork but mine is a ls1 so it may be diffrent. I think you can do it 1 or 2 ways. 1 un do the quick disconnect and un bold the tranny and than remove the slave when it is out of the car. or you can do it the hard way (the way i did it) which is unbolt the tranny and have a couple buddys hold it up while you un bolt the slave from the tranny and pull it off the end of the input shaft.
Good luck, Dane
KYWes
Apr 15, 2015 05:48 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
stopthatman
Feb 9, 2015 09:00 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Hurin
Dec 13, 2014 07:38 PM
