A4 shift kit??? Which one?
Old Sep 19, 2003 | 04:53 PM
Knowklew's Avatar
I am lookin into getting a shift kit for my A4 but i dunno if i should get the Transgo Shift kit... Part # TRG-4L60E
of if i should get the B&M Transpak Part # BMM-70365
both at www.summitracing.com
so which is better and all that other good stuff?
Old Sep 19, 2003 | 07:47 PM
thermwood1's Avatar
I have a Transgo in mine and love it. Never had any problems.
I think most people probably use the Transgo kit.
Old Sep 19, 2003 | 08:20 PM
AL SS590 M6's Avatar
Moderator
Another Transgo user here.
Old Sep 20, 2003 | 03:31 AM
revtime's Avatar
Go with the Trans go.
I have one in my built 4L60E and I love it.
Old Sep 20, 2003 | 12:10 PM
unvc92camarors's Avatar
check the boards, most prefferred is transgo
there is a reason behind it
b&m try to alter trannies differently
they try to increase line pressure instead of doing what transgo does: replace the parts in the tranny to make it shift better (firmer)
when you increase the line pressure (they do the same with their 20$ shift cable things too) it just causes the internals of the tranny to break down more rapidly, which you dont want
go with transgo imo
Old Sep 25, 2003 | 10:09 AM
Jilly's Avatar
I got the TransGo and I love it.
Old Oct 2, 2003 | 12:50 AM
Pro Built Automatics's Avatar
Use the Trans-Go Performance Shift kit (modified). If you want to increase the capacity of this unit with a 9.5" torque converter, change the 2nd gear valve body plate apply hole to .096, and make sure you use no more than one spacer in the accumulator, along with the Corvette servo. This will keep the 1-2 part throttle smooth and still firm at WOT. For 3rd & 4th gear change hole size to .155. I have found this to work extremely well in these units, especially if you want it to last in 10-11 second vehicles. This information is from Trans-Go. With the stock diameter torque converter change the 2nd gear feed to .086 (no washer), 3rd & 4th gear to .125. Go to http://www.pro-built.net/index.cfm?f...t&productid=91 for the modified Trans-Go Performance Shift kit.
Old Oct 2, 2003 | 07:48 AM
FastZinTennessee's Avatar
Damn am I the only guy running a B&M here
Old Oct 2, 2003 | 08:28 AM
revtime's Avatar
I have a B&M tranny cooler.
It seems back in the day B&M was the way to go, but I don,t think they have kept up on technology that well.
Old Oct 2, 2003 | 01:48 PM
When I was asking around about a shift kit everyone said stay away from transgo, that was about three months ago Anyway I got a B&M and haven't had any problems.
Old Oct 2, 2003 | 02:54 PM
revtime's Avatar
It depends alot on who builds the tranny or installs the shift kit, B&M should hold up all right.
I think the biggest difference with the Trans Go is at part throttle the shifts are softer and WOT they are hard.
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
TrouserSnake
Aug 7, 2002 12:43 PM
