A4 shift issue
Re: A4 shift issue
The symptoms of a bad mount are usually most obvious whhen you get on the gas and you hear something slam or knocking hard on your floor, mine even did it while shift gears too.
Re: A4 shift issue
Are you sure its just not fuel enrichment for cold startup?
The revs will be up at cold startup and engaging the transmission will cause this jerk.
Does it do the same thing once the car is warm?
Re: A4 shift issue
Could be tranny mount, I would check to make sure all yours mounts are in good shape.
I have a built 4L60E with a poly tranny mount and a BMR adjustable TA that has a poly mount. My car when started cold will jerk and it still does it warm but not as hard.
Check your mounts to be sure, high idle will contribute to this but I don,t think 800 is too bad.
Apr 16, 2015 09:57 AM
armedtrigger
Feb 24, 2015 08:30 PM
