A4....M6... What are the differences
Old Jun 12, 2004 | 09:53 PM
hawkZ's Avatar
I've read here and there about the two but I was wondering if someone would post all the differences. I tried to search but A4 and M6 aren't three letter words so looking through each forum individually isn't something I have time for. Thanks in advance.
Old Jun 12, 2004 | 10:06 PM
TraceZ's Avatar
Re: A4....M6... What are the differences
Please specify what type of info you need. Are you looking to do a conversion and need to know the different parts? Are you looking for performance numbers? Gear ratios?
Old Jun 12, 2004 | 10:56 PM
MysticTeal 95 V6's Avatar
Are you asking what A4 - M6 means? Your question is pretty vague.
A4 = Automatic Transmission
M6= T-56 Manual Transmission
The differences should be pretty obvious Are you wanting to know weight differences, rearend gearing differences or what?
Old Jun 12, 2004 | 11:23 PM
hawkZ's Avatar
Sorry I should have been more specific. I'm not doing a conversion I was wanting to know gearing differences and performance numbers would be great as well.
Old Jun 13, 2004 | 12:56 AM
Kataklysm's Avatar
Almost all M6 came with 3.42 gears, I believe few had 3.23 gears while all autos have either 2.73 gears or 3.23 gears. Performance wise the M6 has certain advantages but the A4 has certain advantages as well. It would depend on what you are planning on using the car for...if its just to drive for fun then get whichever you like. Personalyl if you want to make a strip car I would go with an auto, not nessacerily (sp?) an A4 but some type of automatic transmission.
Old Jun 13, 2004 | 02:11 AM
97WS6SCharged's Avatar
Usually when people start building really high hp cars they pull the stock tranny and install a TH400.
As far as ratios inside the trannys go
4L60E
3.06 first
1.63 second
1.00 third
.7 fourth
Old Jun 13, 2004 | 03:12 AM
psychocabbage's Avatar
I always thought it was:
1- 2.66
2- 1.78
3- 1.30
4- 1.00
5- .74
6- .50
Old Jun 13, 2004 | 05:45 AM
Doh! You're right. I see my mistake. I was looking at a 93 replacement tranny, the 94+ was underneath it. My bad.
The 4L60E should be the right ratios though.
I'd like to have a 94+ with the first 3 gears from a 93 though. I guess I'm going crazy.
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
