A4 4.10 owners inside please.
I disagree. My 4.10s pull harder than my 2.73's did at any rpm and/or speed. A 2 gear drop with 2.73's is roughly the same thing as a 1 gear drop in 4.10's, both will land you at about 4000rpms right in the meat... The 2 gear drop of the 2.73's takes longer too...
thats a pretty good price for those gears are you sure thats 2 series gear i really dont know about the quality of them.i got richmond the do whine but they are some of the stronger gears out there.they are like 190. or somewhere around there.
I have 4.10s in my A4, and love them. My dad has 373s in his z and on the highway we cruise at almost the same rpm, the reason being i have 18's on the rear. But from a stop the gears will pull like crazy. Go with the 410s you wont regret it one bit.
If you are seriously looking into doing a gear swap, I highly recommend the Thunder Racing gear package. You get your choice of gears, a t/a girdle and stud kit, install kit, fluid, and additive.
with 3 series carrier, they are $400 total, and with 2 series carrier they are $435 total...
http://www.thunderracing.com/catalog...&vid=4&pcid=68
Like if im going i guess about 40 or and punch it it takes about 2-3 seconds before you feel the powerband come in to play or like a flat spot nothing that slams you back all over again, but how would that feel with 4.10's compaired to 3.73's
The 4.10's are installed!!!
I can't tell you guys much about how they work yet, because OF COURSE, it's raining!!!
What I CAN say is this:
- They're Richmond 4.10's, built for a 3-series carrier (originally a 3.23 diff).
- They only whine a little bit (hardly noticable) on acceleration. Not even half as bad as my 3.73's whined last year.
- They do not whine at all while cruising or decelerating.
- At 80 mph, 4th gear and lock-up, the revs are about ~3100 RPM!!!
- Under light acceleration, the transmission is into 4th gear and lock-up by about 40 mph!!!
- Even in the rain, traction doesn't seem all that bad surprisingly, however I just got new tires on Friday
. - I can't wait for some dry roads to really try these out.....I think they're going to haul a$$ off the line!
- I really can't wait to get to the track
.....I'm going to get E/T Streets this year, so hopefully 1/4 times will drop a lot
