97 4L60E in a 95
Old Dec 31, 2006 | 02:17 PM
BoltOnZ's Avatar
97 4L60E in a 95
Ok, back in March I had to replace my transmission. I had put a 94 transmission into my 95 Z. We had to disable code 83 to get the TC to lockup. Fast forward to now. just had a 97 transmission put in, with the 94's tailshaft due to the speedo connector being different. We re-enable this code since it applies to 95+ tranmissions, but my TC still isn't locking up. What can be the problem?
Old Jan 1, 2007 | 09:01 AM
jay_lt4's Avatar
any trans codes,, you have to drive it with a scanner hooked up and see if the pcm is commanding the tcc on or not, and verify there are no trans codes or engine codes
make sure to use a scanner that can get trans codes and data not just engine data
Old Jan 1, 2007 | 10:07 AM
12SCNDZ's Avatar
Is this the car Shon is working on? If so, I've PMed him back and forth about some things to check?
Frank
CPT
Old Jan 1, 2007 | 04:37 PM
BoltOnZ's Avatar
Yeah this is the one he's been working on.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
