95 T56 disengaging problem - Oil soaked clutch?
I picked up a '95 Z from a buddy who was having problems w/ the clutch.
He installed a 6 puck clutch, worked great. Car Leaks oil, can't tell where from yet - it's everywhere
Slowly the clutch wasn't disengaging correctly, he thought it was a bad Slave - replaced it. Then he thought it might have air in it.
I took it out, stood it on its end (hose up) and pushed it all the way in, no bubbles came out of the master....
I'm stumped.
Anyone had a clutch soak up oil and swell up? I don't think it's that bad, I don't have puddles in my driveway, but the engine and trans are wet from oil.
I'm going to try and shim the slave on the fork w/ a washer or a nut, just to see if I can get it to disengage....
It just barely doesn't disengage, it's sooo close!
Any ideas? what should the fork feel like for loseness when the slave is out?
I'm stumped.
stockssn2o
May 25, 2015 08:54 AM
