94 z28 gear ratio?
Old Mar 10, 2009 | 10:27 AM
Tanner_94_Z28's Avatar
94 z28 gear ratio?
so my camaro z28 is a 94 but it don't have the z rated tires and the speedo says 110....so i'm also gonna guess that the stock gears in the rear end are not 323 but really are 273 is this right?
Old Mar 10, 2009 | 10:42 AM
Z28SORR's Avatar
According to the info I have the 2:73's were standard with the automatic. So yes.
Old Mar 10, 2009 | 10:50 AM
well that sucks but im putting another motor out of a 94 trans am but could i take the rear end gears also out of the rear end and put them in my z28 also
Old Mar 10, 2009 | 10:56 AM
Z28SORR's Avatar
Might be easier to swap the whole rear end.
Old Mar 10, 2009 | 10:58 AM
so i couldn't just take the ring and pinion out of the TA and swap it out with the ring and pinion with my z28?
Old Mar 10, 2009 | 01:18 PM
94arcticwhiteM6's Avatar
should be doable. are you sure you only have the 2.73's? what RPO do you have?
Old Mar 10, 2009 | 01:29 PM
Robwhartlt1's Avatar
this is something that gets ask allot here. but yes you have 273 gears in your car. and another way you tell is if your shifter onley shifts to 2nd gear you have 273 but if it goes to first you have 323.
Old Mar 10, 2009 | 03:51 PM
bombebomb's Avatar
2.73:1 you mean.
Old Mar 10, 2009 | 08:15 PM
Come on man I do all this from I phone. So sorry if it's not understandable for you.
Old Mar 10, 2009 | 10:57 PM
Wrong forum.... moving to "Drivetrain".
Old Mar 12, 2009 | 11:13 AM
Z28SORR's Avatar
Originally Posted by bombebomb
2.73:1 you mean.
Yes, it would appear I have the colon in the wrong place.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
tds1213
Nov 27, 2014 12:55 PM
Jul 4, 2005 05:00 PM
