93 Z28 trans prob
Old May 2, 2007 | 01:13 PM
Stephen G's Avatar
93 Z28 trans prob
Hi,
I have a problem with the trans in my 93 Auto. I was driving and I stepped on it only lightly and I heard a Big bang and it stopped. I did it again, it did the same thing, then just went into like natural. I took it out of the Over drive spot on the shifter and it goes fine. It does slip at all even under heavy throttle. But now I have absolutely nothing when I **** it the over drive spot, the one with the circle around the D, its like its in neutral. Any ideas what just happened?
Thanks For any and all help.
Old May 2, 2007 | 02:15 PM
Performabuilt's Avatar
Supporting Vendor
Most likley you have broken your input sprag it does the holding in forward in the OD position But the overun clutches do it in the D position. You are gonna need a trans or a rebuild.
Old May 2, 2007 | 05:21 PM
12SCNDZ's Avatar
Yes, this sounds like the input sprag has went. Very common problem with the (weak) SKF input sprags GM used in the late 700's (4L60) and the 4L60E's. We never reuse this type because of this. We always update EVERYTHING to the stronger 29 Element Borg Warner input sprags.
Frank
CPT
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 5, 2015 07:14 PM
rockync7
Jan 1, 2015 05:10 AM
siguy
Nov 27, 2014 10:07 AM
