90+ MPH vibrations
Old May 24, 2007 | 11:44 AM
godspeed1976's Avatar
90+ MPH vibrations
I have always had a wicked bad vibration that feels like its gonna make the car take off after 90+. Its especially bad when I let off the gas (which leans me toward the pinion bearing) This is normally due to a out of balance driveshaft. Ive also heard it comes from a bad pinion bearing.
I know my pinion bearing is bad, and it will be replaced first of next week along with all the otehr bearings and gears. It howls like a loney wolf in Arizona when I decel.
Now I know the previous owner had a few rears put in, the last time he had one put it I can tell you it wasnt done very well (ie. the carrer mains being lose to the point of falling off). I am wondering if the driveshaft was installed upside down, and if I can just turn it 180 degrees to remedy the problem. Unblot it, turn the wheels till the pinion yoke is 180 degrees, and reinstall. Anyone ever heard of doing this before to remedy a similar situation?
Any other suggestions as to what it could be? Another friend swears its the stock torque arm. I have LCA, and relocation bracks as well as lowering springs that he says has thrown my pinion angle all off, and that is the cause of the vibration. That I need an adjustable torque arm to fix it.
Im at a loss...any help would be appreciated.
Old May 24, 2007 | 03:30 PM
GlueFactory's Avatar
On my car it was the stock driveshaft. Same exact symptoms. Picked up an LS1 DS for $75.00 and fixed it.
Joe.
Old May 24, 2007 | 04:31 PM
Where did you find an LS1 Driveshaft for $75?
Old May 25, 2007 | 01:26 AM
slomarao's Avatar
I got the same issues and I have an ls1 ds
Old May 25, 2007 | 08:17 AM
I dont think its as much a issue with the driveshaft as much as having better /newer ujoints, and shaft balance.
Old May 25, 2007 | 08:27 AM
shock6906's Avatar
Here's one for 100 bucks.
http://web.camaross.com/forums/showt...43#post4623243
Old May 25, 2007 | 10:56 AM
Thanks man! There is one on Ebay for $125 + $20 shipping. I have another friend looking for some too. Place here in Bama has steel shafts for $125 as well.
Old May 25, 2007 | 03:01 PM
stopthatman's Avatar
don't change the u-joints unless they are worn or loose. you'll have to re-balance if you do
Old May 25, 2007 | 04:48 PM
I plan on either replacing it all together (depending on the price, best I found is $125) or all change the joints out and get it balanced.
Old May 25, 2007 | 05:03 PM
125 is probably a fair price for a good DS.
Joe.
Old May 26, 2007 | 03:38 PM
30th6's Avatar
ive got one for sale for $100+shipping with a new u joint.if your interested call me at 256-443-0234.thanks joe
Old Jan 17, 2008 | 04:12 PM
maybe2fast's Avatar
I had that decel problem and went to the LS1 DS and the problem remains...just had my u-joints in the lt1 DS replaced and balanced! we will see
Old Mar 19, 2009 | 04:18 PM
maybe2fast's Avatar
balanced steel LT1 shaft installed...vibs remain
95chwagon
Oct 16, 2015 12:24 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
NewsBot
Sep 14, 2015 09:20 AM
mmf_1013
Sep 12, 2015 08:56 PM
