4L60E trouble shifting to 2nd
Old Mar 3, 2009 | 06:21 PM
camarobird92's Avatar
The 4L60E in my 95 is only a year old. It was shifting great with my stock motor that through a rod in October. I finally got the new motor in last week. Ever since then the tranny slips when its goin into 2nd at part throttle shifts and bounces on the rev limiter for a second at WOT. Once it finally shifts into 2nd, it holds fine.
What controls the shift into 2nd that could cause that?
Old Mar 9, 2009 | 09:16 AM
TTT. Still having the problem. I've noticed that if I let off the gas for a second after 1st gear it wil shift easily. The trans still holds fine once it goes into 2nd.
Could it be one of the shift solenoids going bad? Or maybe in the PCM programming?
Old Mar 10, 2009 | 09:16 PM
After doing a little research, I think it might be the A or B shift solenoids. I think I'm gonna try replacing those unless somebody will help me out with another idea.
Old Mar 10, 2009 | 10:21 PM
MikeGyver's Avatar
Have Datamaster? Scan for PCM and transmission trouble codes.
Old Mar 11, 2009 | 12:17 PM
The Service Engine light hasn't ever came on with this problem. That should mean there are no codes to check.
Old Mar 17, 2009 | 12:25 PM
Updates
I still haven't done the shift solenoids yet, but I have replaced the TPS and checked the VSS. I also downloaded datamaster. No trouble codes that I could find and the PCM is commanding the shift into 2nd.
I have also figured out that the trans isn't going in to 2nd at all. It will skip 2nd sometimes and go straight to 3rd. If I manually shift, it will act like a neutral instead of 2nd.
Old Mar 17, 2009 | 05:39 PM
Performabuilt's Avatar
Supporting Vendor
This being tha case, Your issue is not with the solenoids but some issue with either the 2-4 band or the second gear servo .
Old Mar 18, 2009 | 09:17 AM
If it was the 2-4 band, wouldn't I be having problems with 4th gear too?
The secend gear servo has crossed my mind as a potential problem.
Old Mar 18, 2009 | 12:12 PM
Supporting Vendor
I have seen where the band can be badly burned and hold in 4th since theres generally little load. but i would check the servo and the 1-2 accumulator.
Old Mar 19, 2009 | 07:05 PM
Would the 1-2 accumulator have any effect on downshifting from 3-2? Cause it won't do that either. It acts like it's going into neutral. It's like 2nd gear doesn't exist.
Old Mar 19, 2009 | 08:23 PM
Supporting Vendor
Yes it could as could the servo and band I would take one step at a time check the servo then the accum and last the band
surreybrad
Jul 5, 2015 10:36 PM
kmk7110
Jun 20, 2015 05:53 PM
PCLZ28
Apr 29, 2015 11:56 PM
